Texmaker安装不附带texlive
问题描述:在安装texmaker时,会推荐texlive安装。
sudo apt-get install texmaker Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will be installed: asymptote asymptote-doc blt fonts-lmodern fonts-texgyre freeglut3 latex-beamer libfile-homedir-perl libosmesa6 libpoppler-qt5-1 libpotrace0 libptexenc1 libqt5concurrent5 libqt5network5 libqt5opengl5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5script5 libqt5sql5 libqt5sql5-sqlite libqt5webkit5 libqt5widgets5 libqt5xml5 libsynctex1 libtk8.6 libyaml-tiny-perl libzzip-0-13 lmodern prerex preview-latex-style prosper ps2eps psutils python-pil.imagetk python-tk tcl tcl8.6 tex-common tex-gyre texlive-base texlive-binaries texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-fonts-recommended-doc texlive-generic-recommended texlive-lang-english texlive-latex-base texlive-latex-base-doc texlive-latex-extra texlive-latex-extra-doc texlive-latex-recommended texlive-latex-recommended-doc texlive-pictures texlive-pictures-doc texlive-pstricks texlive-pstricks-doc texmaker-data tipa tk tk8.6 tk8.6-blt2.5 vprerex Suggested packages: gv blt-demo python-pil-doc python-pil.imagetk-dbg tix python-tk-dbg tcl-tclreadline latexdiff latexmk dvidvi fragmaster lacheck purifyeps xindy chktex dvipng t1utils libtcltk-ruby dot2tex texlive-lang-all Recommended packages: wish The following NEW packages will be installed: asymptote asymptote-doc blt fonts-lmodern fonts-texgyre freeglut3 latex-beamer libfile-homedir-perl libosmesa6 libpoppler-qt5-1 libpotrace0 libptexenc1 libqt5concurrent5 libqt5network5 libqt5opengl5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5script5 libqt5sql5 libqt5sql5-sqlite libqt5webkit5 libqt5widgets5 libqt5xml5 libsynctex1 libtk8.6 libyaml-tiny-perl libzzip-0-13 lmodern prerex preview-latex-style prosper ps2eps psutils python-pil.imagetk python-tk tcl tcl8.6 tex-common tex-gyre texlive-base texlive-binaries texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-fonts-recommended-doc texlive-generic-recommended texlive-lang-english texlive-latex-base texlive-latex-base-doc texlive-latex-extra texlive-latex-extra-doc texlive-latex-recommended texlive-latex-recommended-doc texlive-pictures texlive-pictures-doc texlive-pstricks texlive-pstricks-doc texmaker texmaker-data tipa tk tk8.6 tk8.6-blt2.5 vprerex 0 upgraded, 65 newly installed, 0 to remove and 0 not upgraded. Need to get 755 MB/776 MB of archives. After this operation, 1,246 MB of additional disk space will be used. Do you want to continue? [Y/n]
然而我已经安装了texlive,并不需要安装texlive。原来不懂安装原理的时候,我下载了独立的texmaker的deb包安装。本以为这样会躲过texlive的推荐安装,可是以升级时依然会遇到这个问题。因为平时用emacs写tex文档,也就放弃了texmaker安装。今天学习APT HOWTO时才想到即然是推荐包,实际上是可以不采纳推荐的。查看了apt-get文档,果然有选项–no-install-recommends,实验发现解决了这个问题。
sudo apt-get install --no-install-recommends texmaker Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will be installed: libpoppler-qt5-1 libqt5concurrent5 libqt5network5 libqt5opengl5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5script5 libqt5sql5 libqt5webkit5 libqt5widgets5 libqt5xml5 libsynctex1 texmaker-data Suggested packages: texlive-lang-all Recommended packages: libqt5sql5-sqlite libqt5sql5-mysql libqt5sql5-odbc libqt5sql5-psql libqt5sql5-ibase psutils latex-beamer texlive-latex-extra texlive-lang-english asymptote The following NEW packages will be installed: libpoppler-qt5-1 libqt5concurrent5 libqt5network5 libqt5opengl5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5script5 libqt5sql5 libqt5webkit5 libqt5widgets5 libqt5xml5 libsynctex1 texmaker texmaker-data 0 upgraded, 15 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/20.1 MB of archives. After this operation, 74.1 MB of additional disk space will be used. Do you want to continue? [Y/n]
texmaker 并不强制依赖 texlive 组件,texlive 相关的全在 “Suggest” 和 “Recommend” 中,可以指定不安装。
参考 unix.stackexchange.com/questions/122285/apt-get-without-installing-recommendations-for-a-certain-package
方法一
创建空软件包满足 texmaker / LyX / texworks 一类软件的依赖,可通过 equivs 实现。
应该只需要以下三步:
[ol]
] sudo apt-get install equivs
:m]
*] 获取假软件包需要的 DEBIAN/control 文件:
确认 “Provides:” 一行中包含所有需要的依赖。
wget http://www.tug.org/texlive/files/debian-equivs-2015-ex.txt
/*:m]
*] 创建并安装假软件包:
注意默认会在父目录 ( …/ ) 中创建包,若父目录不可写,则会在当前目录创建
equivs-build debian-equivs-2015-ex.txt sudo dpkg -i texlive-local*.deb /*:m][/ol]
具体参考:
tug.org/texlive/debian.html
tex.stackexchange.com/questions/1092/how-to-install-vanilla-texlive-on-debian-or-ubuntu
这是治本之策。
