01:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 430] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 1188
Flags: bus master, fast devsel, latency 0, IRQ 42
Memory at f6000000 (32-bit, non-prefetchable) [size=16]
Memory at e0000000 (64-bit, prefetchable) [size=256]
Memory at f0000000 (64-bit, prefetchable) [size=32]
I/O ports at e000 [size=128]
Expansion ROM at f7000000 [disabled] [size=512]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nouveau[/size][/size][/size][/size][/size]
一直是集显的路过,
没看到报错,应该是装好了吧,
使用起来没有问题不就好了
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Int
egrated Graphics Controller (rev 07) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 3a02
Flags: bus master, fast devsel, latency 0, IRQ 47
Memory at f4000000 (64-bit, non-prefetchable) [size=4]
Memory at d0000000 (64-bit, prefetchable) [size=256]
I/O ports at 1800 [size=8]
Expansion ROM at [disabled]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 3
Kernel driver in use: i915
另一台笔记本的用的也是集显。[/size][/size][/size]
