以前安装flash失败多次,故来询问
安装chromium也不带Flash了
OSX Mavericks adobe.com安装Flash,Safari就能放cctv了
debian的官方源里好像就有flash,好像叫这个名字 flashplugin-nonfree
E: Package ‘flashplugin-nonfree’ has no installation candidate
你需要启用 non-free 源,因为不是自由软件,所以在 Debian 中默认是不能用的,要手动配置。
例如在 /etc/apt/sources.list 补充以下三行:
deb httpredir.debian.org/debian jessie main contrib non-free
deb httpredir.debian.org/debian jessie-updates main contrib non-free
deb security.debian.org/ jessie/updates main contrib non-free
然后再 apt update 再装包。详情请见 wiki.debian.org/SourcesList
[quote=“hosiet”]你需要启用 non-free 源,因为不是自由软件,所以在 Debian 中默认是不能用的,要手动配置。
然后再 apt update 再装包。详情请见 wiki.debian.org/SourcesList[/quote]
could you give me an 163 non free source?
[quote=“cuthead”]
could you give me an 163 non free source?[/quote]
人肉替换一下字符串吧,应该不难。
thank you,your source is slow for my connection,here is what I do on GNOME by vickycq.
su
vi /etc/apt/sources.list
shift-insert
deb http://mirrors.tuna.tsinghua.edu.cn/debian/ jessie main contrib non-free
deb-src http://mirrors.tuna.tsinghua.edu.cn/debian/ jessie main contrib non-free
deb http://mirrors.tuna.tsinghua.edu.cn/debian-security jessie/updates main contrib non-free
deb-src http://mirrors.tuna.tsinghua.edu.cn/debian-security jessie/updates main contrib non-free
deb http://mirrors.tuna.tsinghua.edu.cn/debian/ jessie-updates main contrib non-free
deb-src http://mirrors.tuna.tsinghua.edu.cn/debian/ jessie-updates main contrib non-free
apt-get update
apt-get install flashplugin-nonfree
the flash is working now.
