安装 alsa-utils
配置命令 "alsactl init "
wiki.debian.org/SoundConfiguration
[code]root@oc:/home/shu# alsactl init
alsactl: sysfs_init:48: sysfs path ‘/sys’ is invalid
Found hardware: “HDA-Intel” “Intel Haswell HDMI” "HDA:80862807,80860101,
Hardware is initialized using a generic method
[/code]run vlc
[00000000022b7fd8] pulse audio output error: PulseAudio server connection failure: Connection refused
[00000000022c89b8] dbus interface error: Failed to connect to the D-Bus session daemon: /usr/bin/dbus-launch terminated abnormally without any error message
[00000000022c89b8] core interface error: no suitable interface module
[00000000021bd158] core libvlc error: interface "dbus,none" initialization failed
[00000000021bd158] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
ALSA lib pcm_dmix.c:1029:(snd_pcm_dmix_open) unable to open slave
[00000000022b7fd8] alsa audio output error: cannot open ALSA device "default": No such file or directory
[00000000022b7fd8] core audio output error: module not functional
[00007f7515983dd8] core decoder error: failed to create audio output
[00007f74ec001ed8] dbus_screensaver inhibit error: cannot connect to session bus: /usr/bin/dbus-launch terminated abnormally without any error message
[00007f74f0043828] freetype spu text error: Breaking unbreakable line
QObject::~QObject: Timers cannot be stopped from another thread
run speaker-test to test
[code]shu@oc:/mnt/videos$ speaker-test
speaker-test 1.1.1
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Playback open error: -2,No such file or directory
shu@oc:/mnt/videos$ [/code]vlc --audio pilse
shu@oc:~$ vlc --audio pilse /mnt/videos/D士下山.Monk.Comes.Down.The.Mountain.2015.HD720P.X264.AAC.Mandarin.CHS-ENG.Mp4Ba.mp4
VLC media player 2.2.4 Weatherwax (revision 2.2.3-37-g888b7e89)
[00000000025e2c78] dbus interface error: Failed to connect to the D-Bus session daemon: /usr/bin/dbus-launch terminated abnormally without any error message
[00000000025e2c78] core interface error: no suitable interface module
[00000000024cc158] core libvlc error: interface "dbus,none" initialization failed
[00000000024cc158] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f6544000e58] filesystem access error: cannot open file /home/shu/pilse (No such file or directory)
[00007f6550000958] core input error: open of `file:///home/shu/pilse' failed
[00007f653c0024a8] dbus_screensaver inhibit error: cannot connect to session bus: /usr/bin/dbus-launch terminated abnormally without any error message
[00007f652c043828] freetype spu text error: Breaking unbreakable line
shu@oc:~$
这里vlc播放视频有声音,但是之前打开的网页html5没有声音
运行命令 alsamixer
┌───────────────────────────────────────────── AlsaMixer v1.1.1 ─────────────────────────────────────────────┐
│ Card: HDA Intel HDMI F1: Help │
│ Chip: Intel Haswell HDMI F2: System information │
│ View: F3: Playback F4:[Capture] F5: All F6: Select sound card │
│ Item: Esc: Exit │
│ This sound device does not have any capture controls. │
已经安装了alsa-utils 和 pulseaudio,
现在运行"speaker-test" 会有杂音
然后重启了一下,startx失败了
安装 pulseaudio 的时候 看到这样一段话
[quote]如果你没有运行GNOME, KDE或者Xfce,并且你的~/.xinitrc文件并未引用/etc/X11/xinit/xinitrc.d目录下的文件内容,为了让PulseAudio自动启动,你可以这样做:
~/.xinitrc
/usr/bin/start-pulseaudio-x11
把~/.xinitrc删掉可以startx了,声音正常,之前写了一个启动声音的配置引起的startx失败
从安装过程来看 应该需要安装两个包 alsa-utils 和 PulseAudio
参照debian wiki
